TwinTurbo.NET: Nissan 300ZX forum - try tightening the bolts in phases and in an order similar
Subject try tightening the bolts in phases and in an order similar
Posted by gt300zxtt on June 03, 2008 at 10:06 PM
  This message has been viewed 101 times.
In Reply To ok bad news!! posted by 300z-shaat on June 01, 2008 at 10:09 PM
Message to heads. i follow and inboard to outboard criss cross pattern. i start finger tight, then progressively increase. seal the deal with the 1/4" drive torque wrench.
are far as the gap is concerned, there will will a gap in the metal, but the gasket should make up for the space. there should be no issue if you follow the FSM and/or Rebuild
